Root help.. themed my inc2 done wrong!!..
Hello guys ... I have a rooted inc2 with mikrunnyv1.01ROM.. after i was looking at the mik mik forums, i found this 5 bars big 3G theme which is done using metamorph... So i downloaded it and installed it. Following every step. But it went wrong.. i have no notification bar at the top . I am left with no notifications at all!! Everything is the same just no bar at the top. Cant bring it down or anything.. well after trying to think what went wrong, i noticed that ive downloaded a theme that is NOT for my ROM!!!.. That theme is originally for mikrunny but for the VIVOW version or something like that!!!.. any help on how i can bring my notification bar again??...i just wanted the 3G instead of evdo.. if someone thinks that downloading and installing the right theme will solve the problem plz give me the link because i found a dead link.... Help people ...thanks..
Did you make a nandroid backup before flashing/installing the system modification? If yes, restore that backup.
If not, always remember to make a nandroid backup BEFORE making any changes to your system. This would include flashing themes, system icons (basically any icon that has to do with the status bar, etc), fixing permissions, etc.
If you do not have a nandroid backup to restore, you can always try flashing the SAME ROM you flashed in the beginning WITHOUT wiping data / factory restore. Please make a nandroid backup first and you probably should use Titanium Backup or My Backup to backup your user apps and data in case you need to start over fresh.
If you do not have a nandroid backup to restore AND do not have the original ROM version you flashed in the beginning (ie there is a new version to download), then you will probably be best to start over.
Kratos
Kratos
Yes i do have a nandroid back up... There is not a new version of the ROM yet. So you think taht by reflashing the same ROM will resolve the issue? If yes why did you tell me to flash it without wiping data/factory restore?. I thought when we flash ROMS we always need to wipe everything. Sorry but im new to this ROM flashing and themes.
