Help Help!!! Think froyo bricking my batterys
LcsEvo
Member
Hi like many people I did the update last night. Everything was working great except phone was eating my batterys every 4 hours or less. I have 5 batterys. So tonight I put in my battery that came with the phone and went to market and my phone shuts off. It was on the charger and the lght that goes from red to green started blinking red and then just stopped. It will not cut on or anything. So I switch batterys and it works till it does it to the second battery. same exact thing. So i switch batterys again. I switched batterys then did a factory reset. The phone is not cutting off on me now but the batterys that it did cut off for are not working still. Should I take it to sprint? anyone else having the same problem?
It seems the factory reset fixed the issue, correct? Do you have a charge dock? It might be that the ones you have issue with are simply too low for the phone's changing circuitry.
