Hi all,
I have an app that has created an annoying window which can't be closed. Weirdly, it is only visible when my phone is held "in landscape".
On windows systems there are programs to help investigate open windows, often using crosshairs, and kill the window or program associated with it... is there such an app in Android???
Thanks in advance...
[Edit] I can't provide a screenshot, but the window looks like a Facebook login, but isn't listed in the regular app list, and does not close when Facebook is forceStopped. I think it was started by one of the floating apps, which I had installed and "played with".
