Root Help to install App2sd on x8 with ROM 2.1(i already rooted my device)
ihsan123
today,i have succesfully rooted my xperia x8 2.1,but when i follow the step to install app2sd,im stuck at command promp step,when i key in "adb shell",it replying "error:device not found",i should get $ sign but i get an error message instead,can someone help me?
i already set the screen timeout to 30 minutes,in case the Superuser program would popup and show "allow" notification,but nothing appear on my phone screen :(
i think u cant install in 2.1,though you have rooted it.u need to install xrecovery and install custom rom floyo 2.2.9,i have done it,and let me tell u,its working amazing.2.1 eclair sucks
true that eclair sucks i recommend use custom rom 2.3 ginger bread
hi ihsan123,
2.1 (eclair) does not support apps2sd. you can use link2sd.
Hey guys, so i've been up for quite a time, trying to get this stuff working, i've read a lot through the forum..
I've rooted my phone, installed Xrecovery, and now im at the app2sd..
So.. at the cmd taskbar, i typed "su", granted permission on the phone, and then was supossed to type "sh /sdcard/app2sd.sh" and see a screen.. as the "suhel28" guide says..
but instead i get "sh: Can't Open /sdcard/app2sd.sh" on the cmd.
I suppose i must change 2.1 to any other room then ? or use link2sd since i cant get this one to work?
Or .. , i've also read this
Thanks for that, but a new problem arose when I got the "su" thing going. I finally got super user to allow the action, but now I can't get the "sh /sdcard/app2sd.sh" going. all it says is that I can't open it? Any ideas why? I've seen another thread that's in exactly the same pickle.
Hmmm. I think I just enabled app2sd, but i'm not sure. While I do have that 127 or so MB free on my phone, how do I know what apps are now on my phone and what are on my card? Sorry for being annoyingly curious about this.
Check if there is a folder named SD in your phone /system
Already tryied to move the "sdcard" to the system on the phone with Root Explorer but the folder was empty/ or it would say insert sdcard since i had formatted it earlier to start the app2sd process...
Kinda confused around here, going to read a bit more and try something.. while i do that if anyone can help me, i would gladly appreciate it.
Regards.
EDIT 1 : Ok i got it done, what i was doing wrong was, i didnt had the phone " charge mode " and i had to rename "PHONECARD" to "SDCARD" on the computer, cmd wasnt detecting the sdcard 'cuz it was named phonecard, also the folder had this name "app2sd2.1 mod (dalvik-cache to sd)" on the sdcard , had to change it to app2sd and inside of it was the file we need it for the cmd "app2sd.sh" ..
so it would be like this "sh /sdcard/app2sd/app2sd.sh"
I guess most ppl was just extrating the folder and put it on the sdcard, but this way u have to rename the folder and do it like it is up, also when u plug the phone, at least for me, it shows "PHONECARD" and not "SDCARD".. so cmd wouldnt find the right path.
So im done, after like a full morning of reading xD thanks to the community/ and suhel above all for the guide..
Regards.
