Help unlocking Lg L9?
milik
I have a LG MS769 (LG L9) from MetroPCS.
I already purchased an unlock code.
I go to the hidden menu using 2945#*769# but when i click on "Network Unlock",
instead of getting the box to enter my unlock code, i get a message that says "You're phone is not personalized".
Pleaaase help! maybe someone knows a different way to enter my unlock code??
any info would b appreciated.
thanks.
Have you put in the SIM you want to use? Either the phone isn't locked, or it'll ask you for the unlock code.
That happened to me also, buy you ened to use thye SPC
code
Service provider lock
the conmpany i used gave me like 6 codes
and SPC was the good one
not the sim lock
i got a metro pcs L9
so i insterted a sim card
and nothing was asked on the screen until i typed the code you have typed
then i selected same option as you and i get the same message
but SPC was the good one
now i can use my tomobil service sim on the mtro pcs l9
SPCK
that one will do
Service provider unlock... not Network unlock
code
not the sim lock
SPCK
that one will do
yea...dats wut i figured.. i guess the company where i purchased my lock code only gave me the network unlock code. been asking them for the spc code but no response...guess i just gotta purchase from someone else or keep hounding em. thanks tho.
I used safeunlockcode
not the cheapest they charged 14.99
but gave me like 7 codes
SIM PUK code included
( well i never locked the sim card )
but if you password protect your SIM and fail like 3 times to unlock it
they ask for the PUK
and if you dont have it you are out of luck
