I have checked the other threads similar to this, but nobody seems to be having the same set of problems, and I have had to reset my phone to stock 5 times now trying to get this thing rooted.
When I start, my HBOOT Screen shows the following:
When I run Unrevoked3 using the instructions in the "rooting for dummies" thread, it runs through what looks like a complete install, then gets to the end and says Done on the computer, but the phone shows errors:
I have read that you then have to put the unrevoked-forever.zip onto your SD card and then flash it with the recovery. I did this and everything seemed like it was working. I saw the superuser icon in my apps, but when I installed Titanium Recovery or Rom Manager they both say they cant get root access.
What am I doing wrong?? It seems like it is getting partially through the rooting, but then not putting it into true root mode. help!?
SUPERSONIC EVT2-2 SHIP S-ON
HBOOT-0.97.0000
MICROP-041f
TOUCH PANEL-AMTEL224_16ab
RADIO-2.15.00.09.01
Aug 19 2010, 14:29:08
Verifying system type...
E:unsupported radio version
E:Update failed. Check /sdcard/soff.log.
E:Error in /data/local/unrevoked-forever.zip
(Status 42)
Installation aborted.
that's unfortunate. That wasn't the original problem (as there is a definite problem with unrevoked), but it's definitely your problem now. Just out of curiosity did you have 2.10 before or after you ran unrevoked forever?
