Help updating Xperia Play
Status
Not open for further replies.
Hey guys, so i have a Sony Ericsson Xperia Play R800i (GSM Unlocked) that runs Android 2.3.4, and i live in Saudi Arabia. I recently rooted it using DoomLord's One Click Root Method that uses the ZergRush exploit (locked bootloader). s
I also removed bloatware like preinstalled games, but then wanted my phone to be stock, so I used FlashTool to Flash a stock UK Generic ROM, and it was pretty much successful, the only difference was that i got some UK generic bloatware like Video Unlimited, PlayNow etc., and everything is so far so good. my Xperia says in the notification bar "4.0.2.A.0.42 New system update available" and when i try to update it requires PC Companion.
So i try using PC Companion to update (even though my Version is already 4.0.2.0.A.0.42). But on the second step of updating, "preparing" when the bar is almost complete, it says that Sony Ericsson's servers are overloaded. I reinstalled PC Companion and restarted my phone, but I still get the same message. I did a bit of Googling and people said the solution was SEUS and gave this link, "http://dl-www.sonyericsson.com/cws/download/1/110/61/1309763183/Update_Service_Setup-2.11.7.13.exe" , but that just opens up this: Support - Sony Smartphones (Global UK English)
So what doI do? And why does it say theres an update? Thanks so much! A quick reply would really be appreciated.
PS: If you need screenshots to base your answer, just reply to this post, and i will send them )
talhaismail,
I see you're already getting some feedback in your similar thread in the Xperia Play all-things-root area.
I'll close your thread here since that's where you'll get the most relevant replies.
Cheers and good luck!
Status
