Root Help urooting Evo 4G
toplist
I want to get my phone back to unrooted, locked oow state.
My phone is on unlocked rooted S-ON (pictures)
HBOOT-2.18.0001
Radio-2.15.00.01.15
Android 2.3.5
software number 5.07.651.6710RD
I used the following option to unlock bootloader and root the phone. I suppose this is called HTCDev option. http://htcevohacks.com/htc-evo-hacks...18-with-s-off/
In order to unroot and re-lock, I tried this guide but failed.
1) http://androidforums.com/evo-4g-all-things-root/evo-4g-all-...d-2-3-5-a.html
For this one, when I type adb shell, I can't go forward since I don't get, "#" as it says on the guide.
2) I tried another guide where they suggested to download "PC36IMG_HBOOT_6.17.zip" and "PC36IMG_SuperSonic_GB_Sprint_WWE_4.67.651.3_Radio _2.15.00.12.19_NV_2.33_release_234563_signed.zip" and rename them to PC36IMG, and put it on sd card (outside of folder). I get this:
SD Checking
Loading....[PC26DIAG.zip]
no image
Loading....[PC36DIAG.nhb]
No image or wrong image
Loading...[PC36IMG.img]
At this point, the blue sidebar loads, then I get
Parsing...[PC36IMG.zip] but nothing happens.
Any help will be appreciated.
sorry, i keep forgetting to check back in this forum.......did you figure it out?
curious as to why you want to unroot? all you can do at this point in re-lock the bootloader. you will still get the watermark. in the bootloader it will say re-locked.
in order for you to have it say locked then you will need to re-root and get s-off then you can unroot using the various methods in the guide that mikey posted.
the reason why the PC36IMG files will not work is because you are unlocked only. you will to to get s-off for those files to work.
hope this helps and keep us posted.
