HELP!!! Vibrant Won't Boot
drinkle06
I'm in love with the phone, but the only thing it was missing that I needed was openvpn support. I rooted it and everything went smooth. I then tried using openvpn installer and it couldn't install the needed files. So I tried manually copying the needed files into the system folder. I did a reboot and it keeps getting stuck at the initial vibrant flash screen. I can get into the stock recovery, but there's not much I can do from there. Anyone have any ideas? Is there some way of reflashing the stock image to reverse whatever I did? Any help you guys can provide would be greatly appreciated.
