Help: Vibration isn't working at all!
eitanb3
Hi!
(HTC Desire \ Rooted \ 2.2)
I'm not sure if its some kind of a conflict between apps' settings or perhaps a permissions issue... but all settings are on \ active for vibration, but nothing is ever vibrating in any situation.
Is there a adb permission fix or anything tp fix that?
i'm affraid to do factory wipe cause i'm not sure what will it do to my apps \ files \ contacts \ widgets (?).
any help will be highly appricated!!!
Thanks in advance!
Eitan
P.S. i'm not sure this is the right forum, feel free to move this tread to the right one.
Hi!
well yes i've changed \ installed many things,
what is "gyro" ?
will it help to do a factory reset? will it also effect my widgets\contacts\applications\so on?
Tnx again.
