Hi. I just got the Samsung Fascinate. This is my first smartphone, so i've never downloaded apps. Anyway, I downloaded a gba_bios.bin file and I created the subfolder "gameboids" inside the "game" folder and moved all the roms I downloaded to the gameboid folder. Now here's what happens
1) I open the gameboid app
2) it asks me to select a ROM and it presents a list of all my roms
/sdcard/games/gameboides
3) I select gba_bios.bin
4) the screen transitions to show a gameboy controller with buttons to click on (they vibrate)
5)This is where I get lost. I have no idea what to do afterward. I did everything but actually load the ROM.
Can you help me?
THANKS!!!
do u have any other suggestions about where i can download a different one?
I'm assuming you want to use the Gameboid emulator, so here are the steps for that:
1) Download Gameboid from the Market.
2) Download the gba_bio.bin file on your computer (I got it here: gba_bios.bin)
3) Hook your Droid up to your computer with the USB cable, pull down the notifications window and select "USB connected" and then Mount.
4) Go to your SD card and create a folder (I used "games") and then a folder for your Gameboid bios and roms (I used "gameboid") so you have sdcard/games/gameboid.
5) Copy the gba_bios.bin into the gameboid folder.
6) Download .gba rom files for the games you want and put them in the same folder.
7) Turn off USB Storage, open gameboid, navigate to your gameboid folder and load the rom.
8) Start playing!
OK have the Bionic and just installed gameboid and bios. Ive tried multiple different roms both extracted and not extracted ill get to the screen to load the rom and click on one then the screen will go black like the gameboid is going to start but then i either get kicked back to the load rom screen or my home screen. Do i have to change the filename of these roms to get them to work? Ir is my gameboid player at fault?
