Root Help w/ sbf
northernmoris
How do I do this part:
"SBF INSTRUCTIONS: Install the RSDLite 4.7 program by double clicking on the program.
Move the pst_flash.ini file into the following folder --> Program Files/Motorola/RSDLite
Where do I find that to insert the file?
computer -> C: -> Program Files -> Motorola -> RSDLite
Yeah.. I got that figured out, now my problem is I have no start option in rsdlite when i pull up the sbf?
i had the same problem. after about an hour of pulling my hair out, i renamed the sbf "dx.sbf" and it worked. dunno why shortening the name did the trick, but it did. give that a shot.
Ok, well that did the trick... In progress, so we'll see if i'm in the clear... TY
sure thing. i have no clue why this is/was an issue, but i'm sure glad i decided to try that. i never woulda been able to fall asleep tonight with my phone in a boot loop.
