Help Help! why is this happening....
MrBaker22
Well this morning i noticed my battery was draining really quickly, so i checked battery usage and the awake bar was solid yet the screen on bar had a few thin lines because i hadnt used it much...
so i went itno betterbatterystats and checked the wakelocks and this is what i found... i have tried everything to get rid of it and cant seem to... any ideas?
P.s i have changed nothing on my phone it just started happening this morning
Look in your latitude options and make sure you have not enabled history, check-ins etc.
