Root Help with a couple of issues, please!
So I successuly rooted with Revolutionary, and I setup this ROM (Im loving it, check it out!) but I have a couple of issues, and I was hoping some of you would have tips on solving them. (Attached a pic)
First, the flash wont work when the 4G antenna is on. I have tried rebooting several times but I haven't been able to find an answer.
Second, upon rebooting, the icons of the apps on the sd card don't show up on the home screen, only way to bring it back right now is to remove the app from the home screen and then insert back again.
Three, when trying to move apps 2 sd, its very flaky, literally. The size keep flickering and I have to press move to sd several times until it works. Any ideas?
Any help would be appreciated.
1.this is a port from mik3d which is alos a port of the evo3d rom. i guess in sense 3.0 you cant flash while in 4g. not sure why you want to use 4g while taking pictures. just turn 4g off for pictures and turn it back on when done.
2.are you moving the apps to the sd card via apps2sd? it could be the links to part of the apps are getting corrupted. try wiping dalvik cache and cache and see if that helps.
3.no idea what you are talking about unfortunately. size keeps flickering? what does this mean?
also you may want to get a bigger card with a higher class. i have a patriot 16g class 10 card. once you do that you can partition your card. here is the guide if you want it:[GUIDE][07/07/11]How to Partition your SD Card - xda-developers. you should have at least a class 6 or higher.
LOL. This just seems weird to me. I know that I would never have noticed this issue... How is everyone so aware of it !!?!
Thank you very much for the reply, appreciated. :)
1. I always have 4G on, I get great reception fortunately in LA, so I just thought if there was a solution, it would help me out because its frustrating sometimes when you want to take a quick pic...
2. I will try that out! Moved them to phone storage for now..
3. When going to "manage applications," and selecting an app, the the size of the app that's shown, like "tota 5MBl" and "application6MB" change constantly for 10 seconds, and then it stops. When I select "move to sd", it will try to do it but then the numbers will again start changing several times, sometimes it works, sometimes it doesn't. lol Thats my best way of explaining, its freaking weird.
I leave 4G on because I'm simply too lazy to toggle it every time I want to use it, I have an extended battery, and I am rarely away from a power plug for more then 6-8 hours at a time.
Somehow I doubt this is a "3D" thing as HTC woulda caught flack about something so simple. It is likely more of a "3D Rom" thing right now.
Pray the devs that be come up with a fix/workaround.
Yeah same here, leaving 4G on all the time is easy for me, battery is not a big issue since I am always charging. I hope so too that they find a fix for it!
