That beats and audio app you may want to drop you don't need that and volum + . Speaking cause when i installed volume + that beats and audio was force closing . Try it without it i noticed this dsp works well or try this new app called jet audio very nice and yes it has crossfade which a lot of apps don't and it sounds nice with or without headphones .and you can see jet audio works as where you can't with beats and audio
i have to but you can delete that beats and audio and try the headseticon its in the google play store and it has the beats and audio icon in the notification bar alsoI know beats audio app causes volume + to force close. I just have the beats app for the notification its not actually installed on my phone so volume+ works. I've been using jet audio since they made it for android about 2 months ago. volume + is an overall equalizer which changes the sound of my entire phone so it actually makes my phone louder. jet audio is just a music player you only get its goodness when listening to music from it. I use volume+ and jet audio as a combination. You should try it
:smokingsomb:
