Help Help with Bluetooth Issues
dosage0
Hello all,
I have the HTC One SV and the phone itself is pretty nice. I am having a major problem with bluetooth headsets, however, and it is driving me insane. I have tried 3 separate headsets and two of them echo like crazy for the person on the other end of the line. The third one is a Jawbone ERA and it doesnt echo but it sounds like I am in a tin can and its difficult to hear.
I called HTC and they just want me to factory reset the phone over and over. I have tried that and it doesn't do anything to help with the problem. I am on 4.0.4 and am wondering if anyone else ran into issues?
Is there a bluetooth protocol that will work better with the HTC One SV than the others?
Thanks in advance,
well sorry for taking so long to respond. I have the HTC One SV also and I'm not experiencing the problems you are. I'm using LG Bluetooth headsets and they seem to work well.
I have the same complaint. Phone sent in to HTC twice (1st fix was to replace main board) but no fix....they said they are "working" on a software fix. :mad:
No problems at all with bluetooth here. Mine connects to everything. Computers, headsets, other phones, and my car. No problems whatsoever. No echo at all with car or headset either. :thumbup::D
Sorry to hear you're having problems.
Hello all,
Thanks in advance,
Try updating to Jelly Bean the official update is out go to settings and system updates.
Sent from my C525c using Tapatalk 2
