Root Help with boot loop
CrimsonToker
Android Expert
Jul 4, 2014
1,103
306
Humboldt County, U.S.A.
My M8 (VenomRom) has a broken power button, which has been causing some weird issues. I can't bring up the power menu when I want, but sometimes it will pop up on its own and refuse to go away. Also, when it is in hboot, as soon as I scroll down one option, to recovery, the power button will hit and send it to recovery. Except right after it says entering recovery mode, it goes black screen, and the normal boot up process starts. It then hangs on the Team Venom screen. If I can't enter recovery and I can't boot up, how do I fix it??
@CrimsonToker Meant to come back to you on this, you still hanging with this? Is it definitely a power button issue, and every so often the phone thinks you've long-pressed and will reboot? If you get it in to the bootloader fastboot mode - this may be best done via adb when the phone is on - will it stay there? Do you have a Win PC and adb/fastboot tools - if not you can find the tools here:
ADB Guide (updated 2014/11/11)
which also has instructions for set up.
Check phone is recognised by opening a command prompt and typing:
adb devices
should return your phone's serial number.
Then type:
adb reboot bootloader
should hopefully get you in to bootloader, so we can then try a few fastboot commands.
If recovery won't load, can try clearing the cache out:
fastboot erase cache
then try to load recovery.
Upvote 0
BEST TECH IN 2023
Smartphones
