Help with BW
For the life of me I can't figure out how to change to the small home display. I don't remember where that option is. Can someone help me out please? Thanks!
small home display?.... do you mean when all the home screens are on the screen and very small.... if so when you are on the main home screen hit home again and it will toggle the smaller home screens...if not then i am not sure what you mean
On the beautiful widgets. You can make the weather/clock small so you can fit more stuff on the screen or you can make it bigger. I have mine bigger right now but want to make it smaller. I can't remember where that option is.
Add widget/clock/select the last one with the right arrow
I forget sometimes too...
Oh, my instructions work with factory widgets, i guess I don't know beautiful widgets. what's that?
I will try and see if that works for BW.
Beautiful Widgets is an app that you can use to change the themes of the clock and weather.
