1) What specifically are you trying to flash?
2) What recovery (clockwork or RA) and what version do you have?
Are you sure it's a package meant to be flashed from recovery? Are there instructions given with it? Can you give me a link?
3) In searching for a workaround a little more realistic for you, I found this post from the thread:
xda-developers - View Single Post - [SPLASH] Custom Splash Screens by 12MaNy
What this person did was take the splash screens that you normally have to install via fastboot and inserted them into an already packaged PC36IMG file, which can be flashed from hboot. The particular file they are referring to is this one:
The instructions for how to flash such a file are given in that link. Unfortunately, I tried to download it, but it looks like it's no longer available.
I too was curious about this, but since it's just a splash screen, I didnt want to put too much effort in, however that link you posted makes it sound like a very easy work around, only question I have is in regards to the "creat an unsigned zip" part of this post
"Here is how i do it:
I create an unsigned zip to be flashed.
Im Fully rooted, NAND Unlocked, and S-Off
via unrEVOked 3.21
1) Download Unrevoked Forever's custom splash screen PC36IMG.zip
2) Open the zip and delete the splash1.img
3) Download the custom splash screen you like and rename it: splash1.img
4) put the file in PC36IMG.zip
5) put the Zip on the root of your SD Card.
6) Power Down your phone.
7) Boot your phone into HBOOT (hold down "volume down" and press the power button)
8) Your phone will automatically find the zip and ask if you want to apply it.
9) Press "Volume Up" for yes
10) It will ask to reboot. Press "Volume Up" for yes.
11) your phone reboots, and you see the new Splash Screen"
How would I creat an "unsigned zip" I dont even know what that is? Or is he just explaining his process? I can follow steps 1-11 no problem, but I'm trying to figure out if steps 1-11 are all thats needed, or if you ALSO have to create this mysterious "unsigned zip" before hand![]()
Thanks
I just downloaded it no probs...
thanks I will try to install a splash screen right now and report back
