Integraoligist
Hey all,
I'm looking into getting a charger for the car... and while i was in Kohls last week came across a universal charger for a DSI. Plugs on it look similar to the DX but i'm not 100% it's correct.
The 12v plug that you put into the cig-lighter just had a couple USB inserts. Then you take your regular charger cord and plug it into it.
Does it give off the correct voltage or no?
I'd like a device like this plus an additional USB cord (like the one that came with the DX) so i can use either of them anywhere... at any pc, at home on the home charger, and in the car.
Thanks for the help everyone!
