Root Help with CM7/CM9 Dual-Boot (gApps problem)
It's still the same, flash CM7, and the CM7 version of gApps. When you install CM9, use the CM9 version of gApps.
You can only install one rom at a time. :D
Both internal? I thought the NC only had 8 gb of emmc storage. Installing both sounds like trouble. I'd think you'd run out of app storage and willy-nilly moving apps to sdcard is a ticking timebomb.
