If you're talking about the default weather widget, there's the News and Weather widget, from which you can select weather. Remeber, this is not sense UI, so the widget will look different. I personally use Beautiful Weather widgets.
Make sure you've flashed after a complete wipe (data + cache + dalvik). Others have reported battery drain without a full wipe. Download the "Super Power" app. It has lots of features that will save battery life by default. You can tinker around with this once you're familiar. Look at spare parts to see which app is using up resources/wake lock. Of course, all this is assuming you've seen this.
