Help Help with disabling start up macro
I went into my Terminal Emulator and wrote "su" so it would gain access from SuperUser, well it gave me a 10017 code and looked it up it says:
"10017
"Please select the start up macro file."
Description:
You have enabled the start up macro option but neglected to select the macro file.
Solution:
Disable the start up macro option
or
Browse for the macro file to be used for the start up macro."
So how do I fix this?
