HELP with eris
zeni
android.process.acore force closes happens everything 30 secs or when i open anything... I need help it started the other day and is extremely annoying!
ya i have a task killer. but i thought it would be something not to kill
i have killed all apps and it still does it
Hi zeni.
You need to go through your apps one by one to find out which one is corrupted and causing that error.
De-install, not "kill," them one at a time, off a list if you have a lot of 3rd party apps, starting with the task killer, to see if the 30 second message appears.
I suspect the task killer, but it could be something else.
This is typically a problem with something "jamming up" when syncing.
Go to Settings > Accounts & Sync
Try turning off Facebook Sync and see if that solves it. If not, then you may want to look at what else is syncing. Turn them of one by one until the problem goes away.
Welcome to the forum.
Thanks i have uninstalled all my 3rd party apps... still no dice... its been a great phone for a yr...
-- Thanks im glad i joined.. sync did not fix it either...
Have you tried OTD's suggestion about Facebook?
Also, what is on your home screen? Any bookmarks? Sometimes they'll cause wiggy behavior.. if so, just remove the bookmark(s) to see if that remedies the issue following a restart (which you should be doing after any of the changes being suggested, by the way).
ya nothing im about to go off to the verizon store... not sure what else to do
Try the suggestions, then try a live battery pull, zeni.
You could save yourself some trouble. ;)
But taking it to the store and/or a factory data reset (which they may do there as an attempted remedy) would be next.
You may also want to try removing the clock/weather widget and see if that stops it.
You may also want to go through your contacts and see if any of them have phone numbers listed as email addresses. Apparently that has been a problem on some of the GSM HTC phones.
