i am new to flytouch android, i have downloaded copilot and its showing in mypad but i dont know how to get it into my apps,and how to get icon for it,any help will be appreciated
So I am trying to understand your question. Are you saying that you installed the app from the Android market and now do not know how to find it on your pad and run it?
If this is the case there is an icon at the bottom middle of your home screen that looks like a cube made up of 9 smaller cubes... tap on your screen and this will take you to a list of all of your apps. Once there, find the app in question by scrolling through them and tap on the icon for it.
That should be it. Pending on your version of Launcher you can create shortcuts to place them right on your desktop by holding down on the icon for a few seconds then drag it to the desktop.
