Help with Folder Organizer & Toggles - how?
EVU
Is there any way in FO to change icons/labels of Android toggles like GPS/Airplane/4G/Mobile?
They don't show up under any of the change options for FO at all like the apps, settings or even shortcuts.
Wifi is considered a settings so is eligible for change but not the above? Am I missing something?
Not sure what phone you have but do you have an option for widgets?
Have an EVO 4G (NON-rooted) with the stock native GPS/Airplane/4G/Mobile toggles.
But wanted to change the icons using FO.
Not seeing it.Thanks.
How about, getting a separate toggles app and changing the icons on those?
Yeah - just researched on one preliminarily: 4G Toggle
Wasn't an app - just essentially reskinned the natiive 4G Toggle widget so I couldn't apply any changes to it via FO.
