Root Help with forcing update
oddawson
When i go to the recovery screen with the exclamtion mark inside the triangle i don't know what buttons to hold and for how long. When pressing the volume button is it only the up part, the down part, or both?
Can you guys please help??
what exactly are you trying to do? and to get into recovery pull your batt with your phone unplugged, put the batt back in and hold down "x" then hold down the power button while still holding down x... i am guessing this is what you are trying to access??????????
i just got to the shell and when i apply the update.zip it doesnt verify whole-file signature and it aborts. Does that mean i should try to find a different update?
