Root Help with Harmonia ROM
zmauls
I'm running Harmonia and I can no longer instantly attach a recording to an SMS/MMS by using the Voice Recorder app that came with my phone. In fact, it doesn't seem to be there at all. Any way I can fix this?
Why not just reinstall the latest Harmonia without wiping out the data? You can and should wipe out the cache and dalvik cache however....
Just download one of the numerous voice recorder apps on the market, there is no easy way to see system files on your computer, just what's on the sd card.
Voice Recorder was removed from Harmonia a while back. You can easily slip it back in using Es File Manager. Others will work, but you will have to mess with permissions, ES File does it automatically.
Mind if I ask why you chose to remove it?
Because this rom is supposed to be as light as possible, while still being close to stock. live wallpapers, other apps that were removed can be easily put back in, if the user wants them.
