Root help with KingsRom UNleashed R5
britts676
Flashed this last night and tried to put theme on the phone downloaded the theme flashed the new theme( gravityonice 4x4) after wiping cache and dalvik flashed the new theme and it is stuck in the boot screen I have to pull the battery go back into recovery and reflash the rom please help
i moved you to the rooting section
make a nandroid first, then try flashing the theme that way you can just restore back rather then trying to reflash the rom.
try re-downloading the theme. it could be a bad download.
