Root Help with live wallpaper!!!
seanyboii
Ok so i downloaded live wallpapers and they worked but made my eris EXTREMLY slow setCPU showed my eris clocked at 228MHZ so i want to remove my live wallpapers but i have no clue how. i went to manage apps but i can't remove them from there and the live wallpapers also changed my lock screen from the HTC sense lock screen to the Froyo jump lock screen (the slide thingy with unlock on one side and sound profile on the right side) guys i've been going at it for hours trying to get rid of live wallpapers..plz help
ok seriously guys can you help me. im new to rooting but i've had my eris since november of last year. I finally deleted the live wallpapers without you guy's help using titanium backup but im still stuck with this stupid jump lock. Can you guys help me get my sense lock screeen back
I've never used Live Wallpapers, so don't know anything about them.
I hate to suggest this, but you could try a factory reset to fix the lock screen. Or you could download a problem called Widget Locker, which allows you to change your lock screen. *I* am not aware of a way in the ROM itself to change the lock screen.
yea i did a factory reset..3 times no such luck, after deleteing the live wallpapers i rebooted the phone about 6 times no luck. also i used 1 click eris root, to root my phone but it didnt change the lock, is widget locker an app in the market?
Thanx, i was able to get my lock screen back. and I was thinking about xtra sence but i have no idea how to put it on my device. lol
