Root Help with Lucky Patcher (Root)
Andrew__
Hey guys. I have a rooted Galaxy S4 with Lollipop 5.0.1 running. I accidentally disabled ad services with Lucky Patcher, so I was wondering if there was a way to re-enable them.
Thanks in advance:)
Hey Andrew, sorry to hear of your issues.
We normally don't like to discuss that particular app around here since it's primary function helps folks use paid apps for free.
However, it sounds like that is not your particular issue here, so I'm guessing the folks in our SG S4 root area might best be suited to help you re-enable that service or otherwise help you restore/recover your device.
I'll go-ahead and move your thread over to there for you.
Cheers and best of luck!
