can anyone tell me why i cannot install any apps off my sd card to my tablet ????? all i get is parsing error.
disco,android 2.2 20110325,build frf85b,kernel 2.6 32.9
have you rooted or installed Tim's rom? I open the apps through just the file manager and they install fine. Just make sure the file is apk and not api. Took me 2 tries to get that.
i cannot get z4root which i need because only getting free apps off the market.if i do get it will it work off my sd card ? as all the other apk files wont install like i said earlier.thanks
