Root Help with my GPS after flashing....
rob129
Hi everyone, I'm pretty new to all this great stuff that you guys do here. I'm using 7.0.3.1 and everything seams to work great except for my GPS and getting the "SEARCHING FOR SATELLITE". I've done a clean install a couple of times but keep getting the same problem. Thanks in advance for your support!!
Robert
Robert
here is the fix for you. xda-developers - View Single Post - [INFO/FAQ] Unofficial Cyanogen Mod Nightly (6/6 - I'm taking my ball and going home!). also for some you when you flash your sense rom, it helps if you launch the gps and wait 10min so that the satellites can get a good solid signal before applying the fix. hope that helps.
When you say "phone dialer" you mean the dial button on the phone right? Also,what do you mean MSL NUMBER? Thanks again.
download an msl reader from the market. run it and write down the number that it gives. this your msl code to your phone specifically. then do the fix and type in the numbers when it ask for it.
