Hi just got my flytouch 3 but have a couple of problems 1st will not reconise my sd card and 2nd cannot download any apps from android market even though I am connected to the wifi. Any help on these would be most gratful thanking you for your time.
try formatting your sd card from your pc...you may want to try one of the roms out there to fully enjoy the market experience (i am currently using Tim's 4c modded rom and it fixed most of my problems)
Hi thanks for that but I have already formatted two micr SD card to fat 32 and although the cards work no data is visible on them, also were would I get the rom from and how would I install it, sorry to be such a pain but new here, thanking you for your time.
Hi thanks for all your help just install new rom and it is working now only slight prob is with the screen it is a bit out. but very greatfull for all your help soon as I can sort the screen out it will be great any help there.
Hi thanks for that yes that did the trick everything working great, only thing now if I can get a bluetooth dongle to work for the bluetooth gps I have thanks again for all your help folks.
