Help with Optimus
Ok so i was upgraded to this phone after my hero died, and since they dont make them anymore they gave me the Optimus S. So i am having a problem with emails thats are attached with a picture. For some reason every time i go to my sent email it wont show the email thats sent with a picture. So i am not sure if the recipient is receiving my email. Is this a normal issue? Is there something i can do to fix this? A setting a app or something, its driving me crazy that i cant figure this out?
Thanks:o
Thanks:o
It depends on how you set up your email... Some of the setups don't refresh automatically and it'll take some time for it to appear. You can go on a laptop and verify if its being sent. My default email (hotmail, don't use my google one too much) is set up as an active sync exchange, so it constantly refreshes and I don't loose emails that often. Good luck!
