Help with Pandora Application Volume
bluesmuse
Hope someone can help. The volume, when I listen to Pandora on my Eris is too loud. I can't seem to figure out how to lower the volume. I use headphones that don't have a volume control so wondering if someone out there can help me. I don't see anything on the Pandora screen that will allow me to lower the volume.
Thanks for your help.
have you tried the side volume button while using pandora? it worked for me. if you use it on the home screen it just changes the ringer volume.
so you have to have the app running.
Thanks - I had thought about doing that but wasn't in a position to use my phone today so couldn't check it out. But, thanks again, will try that.
just make sure the music is play first just tested it and it didn't start changing the volume till the music started even tho it was running.
