Root Help with phone freezing.
jreink01
Android Expert
I have a Motorola Triumph that I just rooted and flashed CM7 yesterday. Had no problems so far except Ive noticed when I have my phone plugged in and turn my phone off, then turn back on, it doesnt come on. Ive waited fifteen minutes and it still wouldnt turn on. Ive tried taking the battery out, then turning back on and it works. This has happened numerous times with the same results. Does anyone know why this is happening?? Its not critical but it is a nuisance. If I dont have it plugged in and turn it off and back on, it turns on. For some reason, it seems to freeze on off when its plugged in. Please help. Thanks.
ive never seen that.
try again, double and triple wipe everything inside the recovery to make absolutely sure no part of the old OS is conflicting with CM7
