nikeysunfire
Hi, I have Cyanogenmod 7 on my GT540 and it worked good for over 6 months and recently it started crashing on apps more often and freezing, so then after the phone froze once, I had to remove the battery to turn it off and reboot it.
but now my phone is stuck on the cyanogenmod loading screen and wont go past that, the loading screen with the loading arrow going counter clock-wise would stop and wont go past there. Any help would be appreciated thanks!
PS: My phone is rooted and with fastboot installed. Thank you!
