rasputintin
Hi all,
Would some clever soul be able to help me out? I have a UK Orange (but sim unlocked and bootloader unlocked, rooted and running ICS) Atrix, but the internal memory card is borked...in recovery if I try to mount it it says "error mounting /emmc" and I can't see it anywhere, either on a PC or in Android.
I was going to try and SBF with the original UK Orange SBF file, but that is both risky and a bit of a hassle (I would have to root all over again etc). Is there an easier way to get my internal memory working again? I have the output from:
adb shell
# cat /proc/partitions
# fdisk /dev/block/mmcblk0
p
q
and my output is this:
1|shell@android:/ $ su
su
shell@android:/ # cat /proc/partitions
major minor #blocks name
7 0 2048 loop0
253 0 98304 zram0
179 0 15541760 mmcblk0
179 1 3584 mmcblk0p1
179 2 512 mmcblk0p2
179 3 2048 mmcblk0p3
179 4 1 mmcblk0p4
179 5 1024 mmcblk0p5
179 6 512 mmcblk0p6
179 7 512 mmcblk0p7
179 8 1024 mmcblk0p8
179 9 2048 mmcblk0p9
179 10 8192 mmcblk0p10
179 11 8192 mmcblk0p11
179 12 327680 mmcblk0p12
179 13 786432 mmcblk0p13
179 14 20480 mmcblk0p14
179 15 655360 mmcblk0p15
179 16 2097152 mmcblk0p16
179 17 353280 mmcblk0p17
179 18 11233792 mmcblk0p18
179 32 7772160 mmcblk1
179 33 7771136 mmcblk1p1
shell@android:/ # fdisk /dev/block/mmcblk0
The number of cylinders for this disk is set to 1942720.
There is nothing wrong with that, but this is larger than 1024,
and could in certain setups cause problems with:
1) software that runs at boot time (e.g., old versions of LILO)
2) booting and partitioning software from other OSs
(e.g., DOS FDISK, OS/2 FDISK)
Command (m for help): ←[6np
p
Disk /dev/block/mmcblk0: 15.9 GB, 15914762240 bytes
1 heads, 16 sectors/track, 1942720 cylinders
Units = cylinders of 16 * 512 = 8192 bytes
Device Boot Start End Blocks Id System
/dev/block/mmcblk0p1 65 512 3584 83 Linux
Partition 1 does not end on cylinder boundary
/dev/block/mmcblk0p2 513 576 512 83 Linux
Partition 2 does not end on cylinder boundary
/dev/block/mmcblk0p3 577 832 2048 83 Linux
Partition 3 does not end on cylinder boundary
/dev/block/mmcblk0p4 833 1937856 15496192 5 Extended
Partition 4 does not end on cylinder boundary
/dev/block/mmcblk0p5 897 1024 1024 83 Linux
/dev/block/mmcblk0p6 1025 1088 512 83 Linux
/dev/block/mmcblk0p7 1089 1152 512 83 Linux
/dev/block/mmcblk0p8 1153 1280 1024 83 Linux
/dev/block/mmcblk0p9 1281 1536 2048 83 Linux
/dev/block/mmcblk0p10 1537 2560 8192 83 Linux
/dev/block/mmcblk0p11 2561 3584 8192 83 Linux
/dev/block/mmcblk0p12 3585 44544 327680 83 Linux
/dev/block/mmcblk0p13 44545 142848 786432 83 Linux
/dev/block/mmcblk0p14 142849 145408 20480 83 Linux
/dev/block/mmcblk0p15 145409 227328 655360 83 Linux
/dev/block/mmcblk0p16 227329 489472 2097152 83 Linux
/dev/block/mmcblk0p17 489473 533632 353280 83 Linux
/dev/block/mmcblk0p18 533633 1937856 11233792 83 Linux
Command (m for help): ←[6nq
q
shell@android:/ #
Can anyone tell me what to do from here? I'd be so grateful!
Mark
adb shell
p
q
su
7 0 2048 loop0
253 0 98304 zram0
179 2 512 mmcblk0p2
179 4 1 mmcblk0p4
179 6 512 mmcblk0p6
179 7 512 mmcblk0p7
p
q
shell@android:/ #
Mark
