OK, here goes. I have an Optimus V from VM. I rooted it a couple months ago to try to make more room and used move2sd to move some of the apps to the SD Drive. Worked but not enough.
Finally, decided that I would try one of the new ROM's. Settled on the Rom Manager(free) and when I saw how it worked decided to get the pro verison (5.99) so that I could download ROMs and try them.
First ROM I downloaded was the new (Honeycomb?) one and it started to install. Everything seemed to be working the way advertised until it started to reboot. It just hung. I had to remove the battery to get it to shut down.
I rebooted in recovery mode and got the Rom Manager screen. This gave me 9 choices of things to do and I tried all 9 and confirmed with the home key and nothing happens. If I hit the home key again it goes back to the menu. This is how I ended up trying all 9 options. Nothing seems to work.
Any help out there?
Any help out there?
