Tripfisk666
Hi everyone,
I'm basically about to give up with my Desire HD. I bought it on Ebay to replace a badly damaged Galaxy S. It came cheap because the seller couldn't get the SD Card reader to work. Being somewhat of a techie, I figured I'd try to get it running as it could just be a software issue or a simple hardware issue.
Is it possible to root the phone without a working SD Card slot? It is unrooted and S-On.
I've tried just about everything I could find online.
Under Settings>Storage it reads: Total Space: Unavailable, Available Space: Unavailable, Mount SD Card: Insert an SD Card for Mounting...
I have tried multiple cards to no avail, each of which works in a PC.
Just about every process I try, it fails when it starts to send root files to the SD Card (since the phone doesn't recognize it)
Any help would be appreciated.
Thanks
Thanks
