There is a setting for this on or off. Lang & Keyboard, android keyboard, Auto complete and show suggestions, two different options. Infact, I just decided to turn off auto complete as when I am typing something odd like passwords, I don't want it filling in it's best guess.
1. Click the search button from the home screen...
2, type in something and hit enter.
3. When the search results screen opens up, do this:
Menu>More>Settings
4. Flick down about 3/4 of the way down under the heading of Security Configuration
5. Check the box for "Remember form Data"
If that doesn't work, use the other options on that screen e.g. "clear form data" and/or "Reset to Default"
Have you done a battery-out reset?
do you use a task killer?
