Root help with SetCPU and what is the best launcher for huawei ascend
Im trying to set up the setCPU for my Huawei Ascend M860 for Metro and i i was wondering what i need to set everything at in order to have the phone run smooth without lag but also to where my battery last longer then 15 hrs.Also what is the best home launcher for the huawei ascend. cuz i tried almost everyone that is free like adw,go launcher,zeam,launcherpro but i wanna know what would be best for the phone.:D im new to this android system itself so thats why im asking all these questions???
set cpu can be set to dump cpu speed on screen off. i had mine min and maxed at just above lowest (phone down for maintenance, cant look at speed but it's like 240k) on screen off. saves a good amount of battery.
the phone already tops at 600 so leave max there unless you are running icarus1.1 then as low as 3something can be pretty smooth but the 4-500 range is good and saves a little battery.
if you want to play games just leave the max at 600 or they get worse.
launchers are a personal choice but minimalistic ones such as zeam make the phone feel a bit smoother.
As Tokenpoke said, there are lots of launchers and it's all a matter of what you're looking for. I've had my phone for a bit over two months and tried a few of them and finally settled on Go Launcher Ex for a few reasons:
1) The app drawer has an app manager built in and you can show down apps if you want to
2) It has a sliding dock (the icons at the bottom of the screen). You can customize up to three docks of five icons each.
3) It seems to run with less lag than some other launchers out there.
Try a few and see what you like.
