Help Help with starting Calendar
TaraMC
So I just got the LG Optimus V but i'm having trouble getting my calendar started. When I try to add even to my calendar, it says that I have no calendars.
I have a gmail account but i rarely use it, so I tried to add a calendar to my gmail and sync it up with the phone but no luck.
Any body know how to make it work?
hi thanks for that info... but in my account the only thing i have is sync contacts... does that mean i have to factory reset my phone and add all my email info again? to get the calendar?
Just to be clear, you have logged in to calendar.google.com on your computer and created a calendar, correct?
If so, try rebooting the phone, then go back into the accounts & sync settings and see if the calendar option appears.
yes i did go on google calendar (but i did it, after i had set up my account on my phone), i also tried to reboot the phone and the calendar did not show up on my accounts page.
Did you open up the calendar app?
Short of deleting the google account & re-setting it up or doing a complete wipe and reset and starting all over I'm out of suggestions. Sorry.
yup i factory reset it and re-signed in and everything is working perfectly. Thanks for your help digitaljeannie!!!
