Welcome to androidforums, and I hope I can be of help. Before we start I need to know which version of the Atrix you have (AT&T, Bell, Orange...) and which version of the firmware are you running. However my answer works for all versions.
From your description, it sounds like you have an AT&T Atrix and on 4.1.83 (menu --> settings --> about phone --> Build number)
If you are on the AT&T Atrix and running 4.1.83, the only root method that works is gingerbreak. Check out the sticky at the top of this forum.
http://androidforums.com/atrix-4g-a...s-all-versions-no-need-flash-back-needed.html
I am having the exact same issue. I just got my update today.
I have a Bell Atrix, running Build Number OLYLA_U4_0.37.23
This is my first smart phone ever (had it only 2-3 weeks), and all my friends told me I needed to root it immediately! I (somehow!) managed to get it rooted using SuperOneClick, but haven't had any luck since I upgraded.
Any help you are able to offer is *GREATLY* appreciated, and I ask that any instructions you offer me are of the "for dummies" variety.
Thanks in advance!
Looks like they killed the root exploit used by one click on the non-AT&T Atrix as well. So give gingerbreak a try. Info on how in the 1st post of this thread:
http://androidforums.com/atrix-4g-a...turn-stock-other-hacks-atrix.html#post2598683
Now a quick question, I know your friends told you to root, but did you need it and do you still need it? If not, than I would not worry about it.
)I just finished following the directions at that link you gave me. I was able to get GingerBreak installed on my phone, but I can't seem to get rooted. I've downloaded the APK from this link, but no dice. According to Knightdulac on this page of the forums, s/he was able to get it work, and s/he has the same phone and version as I do. I have no idea what I'm doing wrong now.
Sincerely, I have no idea why this has to be so difficult, or why it is so difficult and dangerous to either "performance tune" a phone, or to jump through all these hoops just to get a battery to last longer than 4 hours.
(sorry about the whining. told ya I was a n00b at this)
It's ok, everyone was a n00b once
Anyways, so what happens when you run the app? Does it reboot, also, how many times did you run the app?
A little more info. To gain root access on an android phone, you need to be to able edit the main system folders, which are locked, so we use a file/app that creates a backdoor (known as an exploit) to temporarily unlock the system file and then it places a file called SU (which gives you access to the system folder) in one of the system folders. Once the SU file is in there, and you have superuser app installed, you have root access.
Super One click used an exploit that did not need an sdcard to work. Well Motorola fixed that exploit so it no longer works. So a very skilled programmer found a new exploit and created gingerbreak to use this new back door. The downside is this exploit requires an sdcard. So once you have an sdcard, jus run the app, you do not need to reinstall it.
