Help HELP! (with swype)
Allodile
My swype doesnt work anymore. I tried to type it but it won't work. after it types it puts the blue out lining around the keyboard and then nothing.
Did you restart your phone before this started happeneing? There is a known issue with Swype not working on the Incredibles after a reboot. To get it working again you have to long press on the txt field....click on input method....and swith to touch input....then do it all over again and switch back to Swype...then it'll work fine if that's the case.
My Swype BETA expired today.
Logged into the Swype website and requested the new BETA.
It was sent to my email address in a few seconds.
Followed the instructions (uninstalled the old Swype BETA and installer).
Installed the new BETA.
It works like a charm.
I've been a Swype user since the beginning. It is a great app. I'd be willing to pay alot for this app.
THANKS SWYPE!
That doesn't really help the op's problem lol^
What fyrfyter612 said should work, and is the only solution at this time.
