Help HELP with the Commando
TAZ211
Just got my first smart phone, and boy am I dumbfounded. I would like to change the weather app. from NY City to my home town but can't find out how to do that. I want to be able to look at places that I'm going to be and bring up they're present and future forecast. :confused:
If you are referring to the one that came with phone just tap it, then a screen will come up that allows you to change locations. You may have to enable GPS for it to update the location.
Ken
The stock weather widget is horrible. Download accuweather from the market and then add its widget to your home screen.
Didn't like the Accuweather widget. Am using 3D Digital Weather Clock instead. Rlaces your clock, has weather, battery info, and many other options.
Go Weather is also excellent but felt it was a little much.
