paintballfreek
Hey everyone, I'm new to this forum and this is my first post here. I recently switched over from my rooted LG Optimus V over to a Motorola Triumph. I rooted it with gingerbreak using the guides here and installed CWM and the Froyocream Sandwich ROM and its running fine.
The issue comes when I try to setup link2sd so I can move apps to the card. I created a second partition for link2sd using Minitool Partition Wizard. I have tried creating the partition as fat32, ext2, ext3, ext4. I still get the same result. When I try to mount the sd card in the phone I get the "Damaged SD Card" error. I then have to reformat it in the phone which gets me back where I started with only one partition on the card. I have searched around looking for a solution or similar issues to this but have found nothing that helps.
Does anyone have any ideas of how to fix this? Do I need to use a different ROM for it to work? Because I haven't found any threads where anyone has this issue.
