Root Help with Unroot
Bump
Please guys I need help... I really want to root but only if there is a way to undo it...
There's a user at rootzwiki dot com (psouza4) who is supposedly working on an unroot one-click for the Droid 3.
It's early in the game.. hang in there.
I'd not try a factory data reset at this point because of the rumored bricking of the device if any of the system apps have been removed. I wouldn't try that even if they've been replaced, at this point.
Many of us have successfully rooted our D3s, but good on you for being so cautious (keeping this in mind: http://androidforums.com/droid-3-all-things-root/403653-rooting-your-device-your-responsibility.html). ;)
Unroot? - xda-developers
he did a first unroot but had issues with it so he rewrote it so look for the rewrite. Its at the bottom of the first page and its a on click unroot and a root as well. Also if you froze or deleted any bloatware it will put it back for you. Its the same as the one click root , install on your copmuter, unzip and then plug in your phone and set it to charge only and let it do the rest. Its works i just did it and then re rooted.
When I do root my DROID 3, will I still be able to recieve Over The Air updates, or will I have to unroot my device in order to recieve them?
Android user for only 2 months, so I'm new to this.
Thanks!
This Root and Unroot looks good... Hey guys anyone reading this that has had luck with this unroot method just post here... Its not that I dont believe Spacecasespiff... I just want to see some constitency...
