Here is one of the error messages when using Forever Root Method:
* Type 1, 2, 3, 4, 5, 6, or 7 and then press ENTER: 2
* DROID BIONIC R3L3AS3D Root and 43V3R Root *
* and set USB Mode to Charge Only
* READY TO ROOT YOUR DROID BIONIC WHEN YOU ARE!
Press any key to continue . . .
'adb' is not recognized as an internal or external command,
operable program or batch file.
"* Running zergRush exploit..."
* Wait about 30 seconds for the adb server to restart as root
* Installing busybox, su, and SuperUser apk...
* Installing 43V3R Root...
* All done! Your phone should now be 43V3R rooted!
* Why don't you check out Shift[3]R? You're ready to flash it now
HELP!!!
